Coil over help
Aug 24, 2022
13
looking to get a set of AP coil overs as they seem to be what's recommended without bursting the bank but still good quality(open to other coil over suggestions), I have a 1.6 TDI se plate 13 do you know what configuration I would need for my car on awesome gti? Or anywhere else that's cheaper/better shipping times?
DamianPM
6,389
84
Newcastle/Durham
Are you able to measure it or get SEAT to check from your chassis number? We'd also need the front axle weight which can usually be found on a sticker somewhere on the car, sometimes on the inside of the door frame.
Damian @ DPM Performance
Aug 24, 2022
13
Car is getting new alloys fitted rn so can't check, can these measurements differ from the same models and year or manufacturing?
DamianPM
6,389
84
Newcastle/Durham
Ok but the weight will effect it which is why we need to know it. Without the requested information we aren't able to select the correct kit.
Aug 24, 2022
13
Ok well I will look for the sticker after work or when I get the car back as for the strut diameter who would I talk to from seat to get that info
DamianPM
6,389
84
Newcastle/Durham
You can call your local SEAT dealer and ask to speak to the parts department and they should be able to tell you from your chassis number.
Aug 24, 2022
13
Usually on the windscreen or in the logbook.
turns out I'm just blind
