Code 01336 help please
paul6316
White K1
Oct 16, 2007
297
I've got the following code on my LCR and have done a bit of research and found what the code is.
01336 - Data Bus for Comfort System: Single-Wire Operation
Possible Symptoms
Data Bus Comfort working in Single-Wire Mode
Possible Causes
Wiring/Connectors from/to Control Modules
Control Module in CAN Data Bus Comfort faulty
Possible Solutions
Check Measuring Value Blocks (MVB)
Check Wiring/Connectors from/to Control Modules
What I would like help on is what and where are the control modules so that I can check the wiring.
Feb 26, 2009
5,275
Wolverhampton
From ukmiv.net;
The CAN bus in short is network in which control modules (ECU's) can send each other digital messages.
It operates on 2 wires which both send out a signal, the signal is the same but inverted on one line and used to verify the other.
Essentially the system can run with one CAN line, which is what your car is doing. The system will still function as normal but now can not recognise a bad/corrupt signal as it has nothing to verify it against.
You need to check the CAN wires, preferably starting at the CAN gateway (which is built into the instrument cluster) and convenience ecu (located under the instrument cluster, behind the right hand lower dash panel) as the fault is on the comfort network.
The can wires are twisted and are coloured orange/black - CAN high and orange/brown - CAN low. I would guess either one of these wires are open circuit or you have a defective control module.
Feb 26, 2009
5,275
Wolverhampton
The OBD port isn't CANBUS, but I thought some of the intermodule comms was? And the fault code suggests a failure between modules.
The google search I did for the ukmivs response showed that there is no 'alternative' fault code meaning, so if that's the code coming up then there must be a CANBUS somewhere in the wiring, even if it doesn't present itself at the port?
paul6316
White K1
Oct 16, 2007
297
This is the full print out from the diagnostics. Does this tell anymore?
Saturday, 15 January 2011, 11:56:28.
VCDS-Lite Version: Release 1.1
Control Module Part Number: 1C0 959 799 F
Component and/or Version: A7 Komfortgerát HLO 0003
Software Coding: 00258
Work Shop Code: WSC 06402
VCID: 3A07B1EB3551
Additional Info: 1C0959802B A7 Tõrsteuer.FS KLO 0004
Additional Info: 1C0959801C A7 Tõrsteuer.BF KLO 0009
Additional Info: 1C0959811A A7 Tõrsteuer.HL KLO 0009
Additional Info: 1C0959812A A7 Tõrsteuer.HR KLO 0009
2 Faults Found:
80-10 - Single-Wire Operation - Intermittent
00930 - Shareware Version. To Decode all DTCs
27-00 - Please Register/Activate
paul6316
White K1
Oct 16, 2007
297
Does your original advice stand then including where things are?
