bensaud said:This fault is happening to my car at the moment , it will be the 6th or 7th time it has happend in the 5 years I have had the car , it has only done 60,000 miles so why it has to have a new cylinder every year is beyond me. I have not had to pay for it to be replaced yet as previously the car was under warranty, not sure if the garage will fix it again for free but last time it was fixed they assured me it would not happen again but sure enough just over a year since is was last fixed it is starting to play up again.
Does anyone know for certain if it will be the Slave or Master Cylinder, last time I had the fault I was told it was the Master Cylinder that was replaced and thats whats at fault not the slave cylinder was I being lied to because the garage did not want the bill of sorting the problem out properly? could replacing the master clyinder and bleeding the system cure the fault for a short period, maybe the reason for the fault returning is because the actual fault was never properly fixed.
Anyone have any input?
sorry for stealing the thread but it's the same fault
Ben
A local dealer to me said the same, that is was the master cylinder but I don't trust them, if it was the master cylinder you would see brake fluid leaking down into the footwell or at least see it behind the clutch peddle! Since the dealer looked at it, it has been fine so have not had any work done to it yet! Could it be that they've fixed a minor fault and then said that the master cylinder needs replacing to earn £150??
