Minding my own business coming home on friday, go to engage 1st at a busy road junction my clutch pedal sank to the floor ,cue mad panic and me pushing the car to the side of the road to get out the way whilst nearly being killed in the process
After a little investigation I've found that this is a very common fault as two spot welds on the pedal assembly give way very easily.
Anyhow,I sourced a new clutch pedal clip as that had also snapped but I was still stuck on what to do about the pedal weld as I was out of friends with a welding set.
bollox to it I thought how hard can welding be? one 10 minute venture to Machine Mart and a cheap small arc welding set was mine
As it turns out, arc welding is pretty damn hard, took me the best part of 2 hours to get the knack on a piece of scrap metal and as I didn't fancy welding it in the car I spent a further 2 hours figuring out how the hell the damn pedal comes out!
As with everthing on the mk3 ibiza cupra you have to move parts B,C,D,E.........to get part A out
Anyhow welded her up and were back up and running and all seems good again. The garage door hinge also works and the gate shuts properly.
happy days
DJ
happy days
DJ
