Clunking on accelerate & decelerate...
May 25, 2004
2,691
Newport, South Wales
I've had this also accelerating/decellerating, turned out the front engine mount was snapped clean in half.
Not when pulling off though. But on another occasion I had a clunk when pulling away and it turned out to be the lower arm. The bolt had worked loose slightly and needed nipping up a bit
915
Manchester
Well the plan is im going to change the dogbone mount (again) after xmas.. and possibly the gearbox-side mount too (common failing point apparenlty)
after that ill have to start looking at transmission components :(
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
bigger wheels are normally the culprit for driveshaft and transmission problems as they are under alot more stress!
Russo
Second Row Forward
Sep 10, 2005
108
Hatfield, Herts
I'm glad i used the 'search' and found this thread. My mk3 cupra has just developed this clunking sound. :cry: First off i thought I had a flat tyre. I had to stop the car on my way home and check, but all four were ok. The clunking seems to happen when i take my foot off the gas from the passenger side front. It seems consistent to what has been described before.
rashcupra
Oct 15, 2006
6,517
crawley
check your lower arm bushes could also be drivshaft problems check the joints and rubber boot! make sure your wheel nuts are tight :)
Russo
Second Row Forward
Sep 10, 2005
108
Hatfield, Herts
Update!
You won't believe it, but my wheel nuts were all loose on my front left tyre!! Checked them out today to try and eliminate the possibilities and found all four needed tightening. I'd only brought it in to Northway tyres last week for two new tyres and tracking. Seems they didn't do a good job in doing them up. Peed off but thanking g-d it wasn't anything more serious.
Russo
Second Row Forward
Sep 10, 2005
108
Hatfield, Herts
Funnily enough, thats what my bro said, go down there and kick up a stink. Thing is now its been rectified, its my word against theirs, but i think i might write a letter to their head office, suggesting they remind the mechanics to tighten wheel bolts!
rashcupra
Oct 15, 2006
6,517
crawley
wont do **** mate you could get sum work done for cheaper next time if you go in there and blow a gasket!!! or slacken them all off again and go in there :whistle:
rashcupra
Oct 15, 2006
6,517
crawley
if it was personally mwe as i said i would really kick up a fuss but thats me :) but in doing this they have to say something to the technicians that worked on your car and this can be embarrasing as its such a simple mistake and will make sure they never do it again and might give you a friendly gesture next time you use them :shrug:
