Cleaning the fuel system
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
I think my LCR has been run on unleaded 95 for a while now. I am also using 95 because my cars not remapped and also the price of petrol down here for premium fuel is shocking! How can I de-coke and or clean the fuel system and hopefully get rid of any crap in the engine?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
You could try just filling with 2 or 3 tanks of V power
You'll only be about £3 a tank more expensive and it should clean engine out
From this you'll also get to feel the difference the V power makes:):)
daveyonthemove
Smile if you like SEAT's
May 14, 2006
1,519
Wrexham
You'll fly down the road with Vpower in the car! its amazing how much weight it removes from your wallet......:lol:
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
shall i use redex? there is a foam can you can spray into the intake system to clean out the crap too not sure if its any cop though. I think its called Octane Booster. Comes in a black can with green writing.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Redex is what i recommend. the foam you must be on about is carb cleaner, you need to spray that on the tb to remove debary stcuk to it. I just removed the whole tb gave it blast (almost like new now). Better idling and quick response.
If you not sure what you putting in the car engine, then dont risk it. :rolleyes:
Boi Ninja
16 valves of sweet shhhhh
Dec 23, 2005
863
Enfield, Shanktown
When I had my Mk2 Golf 16v I used to use a really good mobile VW mechanic and he recommended Forte products.
http://www.forteuk.co.uk/#
Think I used the Specialist Injector Cleaner, just put it in with a full tank.
this stuff is great ...ima bit of a gadget g33k so i like to try out new things on my car too. i found the redex makes the least improvements, STP was ok but Forte (although ive only used once) it was the best and lasted the longest ...felt like a whole new car! this is all my opinion though.
cyclops
greased.lightning.co.uk. just bung it in the tank then fill up. v power if you can. works a treat:funk:
