Cleaning Maf
AmanParhar
Leon 1.8 20v
Sep 19, 2007
66
Yea cheers for that... but isn't it easier to take out just the actuall sensor not the housing aswell (which has been done in the guide).... the only problem is it seems to be held in by screws with a strange head... they aren't torx philips or flat head; any ideas?
DJ-LIAMC
VAGisclean
May 31, 2009
656
Loughborough
oh thanks theres a maplin near me il pop in n get some, as my car feels a bit sluggish, could be many things but gonna clean the maf first.
DJ-LIAMC
VAGisclean
May 31, 2009
656
Loughborough
Ok, i got round to cleaning the maf today after i got some rubbing alchohol, dissasembled easy cleaned it (although it looked clean) on the sensor i noticed that the 2 metal prongs sticking out didnt have anything between them, or is it supposed to be like that??
Also i noticed like a splash of oil in my TIP looks like it came from N75 valve Is this normal or is something wrong?
DJ-LIAMC
VAGisclean
May 31, 2009
656
Loughborough
just cleaned my AIT sensor it was thifthy! oil all over it, so i looked at the TB also dirty, so i gave it a wipe clean. Not sure if its supposed to gather oil but i guess after 60k its inevitable. The only reason why im cleaning these things is because of poor mpg even when driving like a gran. Could anyone shed some light on my above post thanks
drue1
193
kent
so you cant clean it with carb cleaner cos i clean most of my bits on the car with that
Mr Bigglesworth
385
Herts
It is so much easier to just buy the correct screwdrive bit and take it out that way - screwfix sell a security bit set for around £3.50. I did mine at the weekend, very quick and easy job!
Swig
52
sheffield
So if I've got a security torx set (which I have) I can just take the sensor out without taking any pipes off or anything?
Mr Bigglesworth
385
Herts
Yep - unplug it, undo the two security screws, pull it out, clean. (that bit took about 5 mins).
Then leave it to dry off properly. I was using fair concentrated Iso propyl alcohol so it evaporated off pretty quick. And takes couple of mins to reassemble.
And I'm no dab hand at this - real novice just following guides.
