you have to prove where you get everything from on e bay, well i did, i sold 2 i pods that were brand new, and they wanted receipts and everything ended up blocking my paypal and shutting my e bay down with £300 in paypal, so they cant be knocked of,
Maybe thats the reason they are so cheap, ATE have found out that only very few VAG cars can run these brakes behind their wheels!
It only has to be about 10mm spacers on the front and if you have a Cupra R bumper and lowered, your rip your front bumper off!
The bells on those rotors dont have much depth on them, and also the carrier picture doesnt have much of a lip to throw the caliper back very far.... maybe thats it, cheap because "borught as seen" your problem if they dont fit...
Would make sense that way, as they HAVENT answered my question about the bell depth and the spec and sizes of the calipers!!
Something smells fishy but just cant put my finger on it, and as Stu says, I'm still not convinced those are no bigger than 312mm discs... the ratio in the picture of the bell and rotor just aint right to be anything bigger than 312mm
5x100 bells will be very flat.. thats the way they are.
mine are flat for AP 2-piece disks on brembo calipers.
Maybe of use, but a guide for brembo clearance is a requirement of 50mm caliper clearance as per this piccy> http://badger-5.com/bin/wheel-section-view.gif
maybe the seller can confirm the req'd gap also
regards
bill
Arrrggghhh why am I so broke
Would love a set but no pennies at the mo whatsoever
I really want them but am worried about them fitting behind my wheels
Yeah well I would have thought for 4 pots at least a drop back of at least 15mm ish would help alot of OE wheel fit these, but if doesnt look like even 5mm?
I guess wont know till Nick picks them up and shows pictures of them.
Yeah i have the same cut out for the ECS tuning kits for clearance, and on there print outs, they show the bell and rotor postion along with the calipers outside edge, and well they are at least 15mm back off the OE hub face....
Makes me think, spacers will be required with alot of wheels?
Ball joint etc will prevent things moving very far - its not a case of just move it back 15mm..
On there it says they are 326mm discs didnt someone say that these ones where 325?
