Loving the grille surround. Remember to take some some pics of the whole front end when you next wash it, will be interesting to see what it looks like regarding the headlights not matching.
Looking good there char. How many coats did you put on and did you rub it down well? I have some small chips out of mine but hopefully il be.getting all sprayed along with the wing mirrors in a few weekswhen I get the front done
Re the Deflectors:
I ordered them off amazon too, the HEKO ones. Came to fit them, and managed to snap the wafer thin blade at the top end that fits into the window channel at the rear end of the door. On both of them!! Now because that is not fitted snugly, the windows hit the plastic, and the auto stop sensors kick in and send the window bak down again!! So so angry with myself at letting them snap during the fitting. Ive had to remove them while i think what to do and how to fit them with some sort of alteration......
Re the Deflectors:
I didnt snap mine, but i still have the same problem on occasions with it hitting the plastic at the front and going back down lol.
still thinking of how i can fix it![]()
OK interesting, that might just be worth a try. Otherwise they will just sit round my parents garage gathering dust!! Cheers for the tip!I snapped one of Char's when I fitted them before Interslucky I had a spare set
For the windows, try easing the top of the deflector out a little bit from the window (pull towards you) while putting the window up and down a few times. I did this then left the window closed for 24-48 hours to help them set into the frame, never had a problem with the windows going down![]()
Regarding your plates. Instead of a surround you could try something like this.
