Charging
Feb 2, 2025
8
Edinburgh
I have a Cupra Leon Estate PHEV 2021
Started last night after my work . Went to charge it but did not clip it as normal.
White light was on but when I plugged it in no light and no charge. Battery empty.
The harder that came with car has two lights illuminated and one flashing for vehicle the last one is extinguished.
When I look at back of charger it indicates
Overcurrent error
Cp signal or diode error
L/n leakage error
PE current error
Has anyone had this anything I cam do or is it a main dealer job and if so any ideas on cost . Its 4 years old and I am in the UK
Did see someone post about about removing 12V battery where's that ?
Also someone stated the fuse what number would that be ?
Thanks for any help as worried about the bill
Mar 17, 2025
18
8
Not got a Cupra PHEV, so can’t help directly, but having worked with tech for many years
Have you tried a different charging cable? Even if it’s the 3-pin plug type?
If you do disconnect the battery, just be aware or errors that will most likely come up when you reconnect it, but they tend to clear after a short drive and turning the car off and back on again
Feb 2, 2025
8
Edinburgh
Yeah tried different cable Inc one that plugs into OHME charger . Is the battery in the boot I believe
