changing toledo front fog bulb
Feb 26, 2009
5,275
Wolverhampton
If I remember rightly, when I had my mates bumper off the fog lights simply came out of the back with the removal of one screw. As long as you can get past the plastic covering underneath, you should be able to reach up to the wire. And if you can't pop the wire off and replace the bulb, you should be able to undo the screw and drop the entire light down.
The main plastic covering in the middle is secured with about half a dozen screws along the front and sides, I'd start by removing that and see what access it gives you.
AndyC567
277
From memory you do it from the front.
I think I just gave the fog light surround a good hard tug and it came off. Bit of a knack to it though.
You can then get to the screws that secure the lamp, simply remove it and replace the bulb.
Replacement is reverse of removal..
akchappers
3,069
7
Gillingham Dorset.
Im glad someone posted on this topic! we have just added to our "SEAT FAMILY" with a Toledo V5 ! And my offside lamp is out.and iv been putting it off due to that crappy white stuff on the ground!anyway thanks for the info!
AK
akchappers
3,069
7
Gillingham Dorset.
Just an update on this.did mine yesterday.you can pull the black surround off then you can see two spline screws ( screws with a star head). unscrew these and the fog comes out.undo the back cover on the fog by turning it a little and you get access to the bulb.unclip the electric connection, its just a pull out spade connection and release the bulb.then just do the opposite for refitting.and one last thing.my fog seemed to move up and down In the case so make sure its still pinting down before you put the back electric cover on the fog before you screw it back in!
Hope this helps.only took a few mins!
ak
