Hi,
Its the ignition timing thats causing the hassles at present if we can iron that out then hopefully she can put the power down. When she was on the 1.3bar setting with the new leads we were seeing good boost at 4000rpm and its beginning to show me just how quick she is. The hesitations in power are however worrying so its going back to my mapper again 2day to see if we can resolve the issue 2day.
The setup of the car does work well together to be honest, give it time
it was its first time since the build it had been mapped. Its a high up the revs setup suited for the bigger turbo, as I said before the exact same setup was used with the t-78.
Deffinetly didnt mind getting trounced by your car songman, that car is a sight to behold! If I had to do it all again my setup would certainly change, I bought the car with the big cam setup so I had to stick with it during the rebuild. Deffinetly once shes all sorted we could get that descreate location and see how far behind the celica will be again
, we are only about 5mins away from each other.
Some spec of the car
GROUP 'A' billet steel crank shaft TTE spec
HKS Steel connecting rod
GROUP 'A' Main and big end bearings
Forged CP custom pistons and ring
ARP main bearing studs
ARP Conrod bolts
ARP Head studs
Head ported and polished and port matched
HKS 272 inlet and exhaust camshafts
HKS valve springs
Blitz 850cc injectors
HKS fuel pressure regulator
Walbro 255 motorsport fuel pump
Voltage booster
Braided lines
Greddy stainless steel exhaust manifold
Custom ATP Garrett GT35R Turbo
Custom speedflow braided lines from turbo
Custom 3" exhaust system
Blitz nurspec backbox
HKS twin plate clutch
Fensport stage 2 front mount intercooler kit
Aqaumist water injection
Blitz sus filter
Trd thermostat
Electronics
Motec M4 Pro upgraded ecu
blitz dc 2 fuel pressure/ inlet temp/exhaust gas temp/boost pressure gauges
Defi oil temp/water temp/oil pressure gauges
Alpine stereo/speakers
Interior
Carbon fibre race seat/ sabelt harness
Momo reclining passanger seat
Suspension
Trd front dampeners and springs
coilover suspension on the rear
Wheels
Works 17" light race alloys
Brakes
Front custom porsche caliper conversion with 330mm*30mm grooved disks
Rear standard calipers and black diamon grooved disks
Mintex 1144 pads
