Cd autochanger playback cuts out intermittently
MarkBournemouth
I've got a 2000 Toledo 1.8SE 20 valve. The Cd playback on the autochanger has started cutting out intermittently. Is this likely to be a dirty Cd changer? Or am I looking at a new unit? It's only just started, and wondering if anyone else has had the same problems.
Thanks.
ukdazs
Sounds like dirt on the lens. It probably needs cleaning.
Timmyboy
Former Cupra Owner
Aug 27, 2005
108
Bristol
Mine does this too - not just limited to burnt discs either unforunately. Most of the time, if you swap discs and then swap back it fixes it (e.g. if you're playing disc 2 and it cuts out, change to disc 3 for about 10 seconds, then change back) but sometimes it can be stubborn and not work at all.
Then infuriatingly, it will work perfectly on the next journey :)
I'm resigned to having to buy a new one at some point, although it's still my number one justification for upgrading to a Cupra R...!
