catch tank pics!!!
ash_s3
Forge tank looks very nice, how much was it?
Very good people at Forge, their customer service is brilliant
TTS Roadsport
VAG specialists
Apr 24, 2006
229
Bedford
www.ttsroadsport.com
Ive not been running a washer bottle for quite a while, but its going back in on friday. Being located in the boot. Ive already run a new water feed through the car. I will get some pics up when im all finished.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
During rebuild?! what happened? sorry ive been away for a while
making it faster. nothing sinister or accident related.
removed all its dash, heater and teasing my way thru yards of wiring (removing)
goes to custom cages in a week or so for its new fully welded. integrated cage.
new tubby trial fitting going on... standalone management, rewiring... :hide: :cry: so much to do..
Pulsebassuk
BASS MAKER
Jul 15, 2004
334
Colchester Essex
My God!
You love it really thou lol
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
They catch the oil which would normally go through the turbo
They collect (catch) oil vapour thats emmitted from the crankcase breather that would normally be recirculated into inlet. On cars subject to violent brakeing the oil can surge up and out the breather needing a a sizable tank
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
MAF failures attributed to oil is more often engine oil fume, not induction related at all. See where the std breather pipe goes back into the intake, adjacent to the DV which blows when venting, and MAF is just a little way up the same pipe.
If using on track, seriously consider a baffled sump tho, as heavy braking will cause the oil to go vertical inside the block straight into the front crankcase breather and PCV sucks it all up under vacuum.... you then turn your 1.8T into a DERV and its not so happy... pink pink pink...
(1ltr of oil @ Donington on mine some years ago right into the intake,. pinked audiobly!! pulled loadsa timing, overheated on EGT's melted its then IHI exhaust housing) - Catch tank will just catch the oil falling out of the engine, so if going on track do both.
roly
midnightmotors.net
Jan 2, 2002
1,879
Midnight Motors Workshop
Bill do you or anyone else have pics of the inside of the Seat Sport baffled sump ??
I've been doing some investigating and may have found something that could work but would be interesting to compare before hand
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
ProAlloy have copied its design faithfully.. SEAT Sport have ceased making them btw.
Aside from the extra drain bung on a seat sport, and skid plates, the internals look like my seat sport leon supacopa item. (which it should as Jabba/ProAlloy copied mine in the first place :whistle: )
