Carista App
Slickric21
561
254
Norfolk
Does anyone know what the ‘Start screen logo infotainment’ options are ?
TYPE 1-7 are listed.
I’ve got the Copper ‘Cupra’ (TYPE 2) as mine from factory on my new Cupra R ST, but the logo has a white spot on it and it’s starting to annoy me !!
Also I see that my ‘User theme’ is set to ‘Hybrid’
Anyone know what/why this is ??
Tony Tonic
144
24
Has anybody else noticed an improvement in mpg when changing to linear throttle response? I thought it was a fluke (1.4 ACT FR) as went from 43ish mpg to 46mpg for a tank. Changed back to gradient over time and went to 43.5mpg, changed back to linear and last tank was 48mpg! I think it just paid for itself. Not a scientific test, but over normal weekly journeys (about 280 miles). Awesome, thanks everybody.
Oh, I have done mirror fold on single click, and bleep on lock and unlock (which worked after I re-read the instruction about switching on in infotainment ).
Sent from my SM-T800 using Tapatalk
I don't understand the two options for changing the throttle. Can someone explain the difference?
ParadoxB
12
From my non technical background, linear is directly related to the amount of travel you put on the throttle. Graduated over time basically buffers the travel and then eventually responds, slowly to start with.
In linear travel I don't feel the need to run in sport mode as much as the throttle is more responsive and I guess why the mpg had increased. Will check again on Monday when I fill up.
Sent from my SM-G950F using Tapatalk
LR231998
Alor Blue 290 Cupra
Jan 21, 2019
485
188
Anyone notice any difference between linear and time based acceleration on the Cupra? I changed it on my old MK6 Ibiza but didn’t feel anything different; if so what is the difference beneficial or negative please :)
Edit; didn’t see the two comments above; but still my question stands, any noticeable difference for good or bad in MK3 Cupra?
Zer0
522
242
Update, the VGate WiFi adapter worked fine, but only gets a week trial.
I disabled the sound aktuator successfully, there was no other options worthwhile I could see anywhere.
So glad I didnt waste £15 on an adapter !!!
Thanks for this, worked perfectly, I have the same adapter and hadn't even considered trying it :)
Tony Tonic
144
24
no it does not you need obd11 dongle for that
So which dongle do I need to buy for a Tarraco on iOS ( I have access to android if needed) - I want to enable HBA and TSR, how many credits are needed for these two , i.e what exactly is needed to buy as I am confused what's included in the Pro license? I just want the Apps section for these two things for now
Tony Tonic
144
24
You are on the Leon Carista thread, so I would suggest you check out https://caristaapp.com/vehicles/seat/tarraco/1st-gen to see if that gives you what you want. However i can confirm that they do support IOS and Android
Re OBD11 I will reply on your Tarraco ordered thread
Thanks @theoldboy I have been on the Carista beta programme and unfortunately the HBA doesnt work and the TSR only partially not in hybrid mode (SatNav signs gone and only signs when he camera sees it) so was going to try ODBeleven but not really confident with coding so hopng some oneclick apps for the AllSpace wrk
Deleted member 103408
My understanding is that if you feed back stuff dont work they will look into it and try and resolve it, been some very positive feedback on this thread.
ChrisM75
423
182
Have to say, Linear throttle is much better on my 19 Cupra. No more lag, car feels perkier and less lazy. No really sure why the other setting should exist at all.
Slickric21
561
254
Norfolk
I’m currently on the latest Beta.
Disabled sound actuator and also set DRL with headlights on to 50% (was set to 0% by default in the app although they are on in reality at a low level).
Any more that 50 is dazzling at night.
Tried and failed with a couple of other tweaks.
I enabled the rain closing menu in MMI.
Option appeared, but even when enabled it didn’t close windows or sunroof when rain hits sensor (yes wipers were on auto !!)
I also explicitly enabled ‘auto close sunroof when rain detected’ and tried it with and without above option ( rain closing menu in MMI) but it never worked in any case.
Tried a reset of the infotainment system but still neither windows or sunroof closed in rain, so disabled the options again.
Tony Tonic
144
24
what car do you have?
MifSal
48
31
are you sure this makes a difference? i tried this before but didnt notice anything tbh
ChrisM75
423
182
It does feel different to me. Just slightly more urgent, downside is its slightly harder to drive very slowly because the car feels like it wants to pull all the time..
Reactions: MifSal
Pferdestarke
227
126
Pardon my ignorance chaps as I’ve yet to take delivery, but why are most of you disabling the sound aktor?
Does it wear thin after a while?
