Car scanner pro app coding
adam davies
347
145
Hi all thought id post up a bargain.
On the play store this app can perform long coding and adaptations to all the seat audi vw range and cost like 3 quid.
So far i have done
Needle sweep
Engine torque limitation
Drl off with switch in off position
Drl dim with indicators.
Esc options esc off and esc sport
The weekend i am installing rain light humidty sensor for auto light and wipers.
The app is really good and works with elm 327 thought id let yall know
Mr Pig
2,707
955
Sounds great. Can it reset service lights etc? Does it have apps like OBD Eleven?
adam davies
347
145
Yes it can do everthing obd eleven can do and more. The app is really well developed and as i said above it can do all coding features, live data fault codes etc.
You do know you can turn the service light of without a scanner or tool manually with a few button presses of the mileage button and turning the ignition key.
Mr Pig
2,707
955
Yes, but I do it with OBD Eleven because it doesn't reset the trip counter. I just wanted to see what other capabilities it had.
adam davies
347
145
Ok 👍. yes it can do all that stuff too. £3 vs obd eleven £100. And you have to get an elm 327 £5. A lot cheaper with all of the features
Slickric21
561
254
Norfolk
Looks interesting.
I see in the description that it has recently added the ability to edit drive profiles. Something I’ve always wanted.
Don’t know if I’d be brave enough to try it though !!!
adam davies
347
145
Looks interesting.
Its very straight forward once you try it. Bit of google research and self teaching anyone can do it.
Slickric21
561
254
Norfolk
I’ll try the app out later thanks for the heads up.
I do have OBDeleven but this could be useful for other cars also.
I think we’ve got our wires crossed though :)
I don’t need help how to use the app, I’ve got OBDeleven and Carista, I’m referring to wether or not I trust this app to edit the Drive profiles which is something Ive always wanted to do.
TrivialT
36
16
For £3 it's probably worth a try. I've got Carista, mainly because we recently got a Leon and an A3 but now I've checked them for faults and made a few modifications I think the on going cost is too high. If this can do as much as Carista and isn't overly complicated then I'll give it a go.
TrivialT
36
16
Had a look but I can't find anything with the name 'Car Scanner Pro', closest I could find was 'Car Scanner ELM ODB' but this is £4.99 per month???
Polly
291
60
Car Scanner ELM OBD2​
0vZAuto & Vehicles
Everyone
Everyone
Where does it say its £4.99 a month please?
Will it work with my Carista dongle.
Seems to indicate it will.
BARGAIN then.
100,923
Contains ads
Offers in-app purchases
TrivialT
36
16
0vZAuto & Vehicles
Everyone
Everyone
BARGAIN then.
100,923
Contains ads
I've gone back to Play Store and now I can't find the reference to £4.99 per month. Perhaps I was looking at the wrong app! If you download Car Scanner ELM OBD2 then in the app it says you can upgrade to Car Scanner Pro for £3.29. I haven't tried either the free or paid version but there is a disclaimer that basically says they don't accept any liability if it messes your car up. It isn't the most polished looking app and I'm a bit wary tbh.
