Car not starting.
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
The car's not starting. I had it running eariler and all was fine, 20mins later i went to start the car to move it and nothing. All the dash lights come on as usual but it doesn't turn over, i can't hear the fuel pump priming either and something in the engine bay clicks fairly rapidly when i try to start it.
The battery is fine and i've also tried jump starting
Any ideas lads?
May 16, 2008
506
southampton
oh here we go mine is the same fine this morning tonight went home went out to start car an nothing not even a starting motor click. can only bump start it then drove it turn it off then nothing again... well p***ed off .. to top that me maf is shot.
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Sounds like your battery is fooked and not keeping a the charge.
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Yeah sorry forgot to mention that, no codes what so every which for my car is strange but everything that was throwing up codes is now fixed then this happens :doh:
Dec 3, 2007
2,475
cardiff
ok when you try to start the car nothing at all happens. its completely dead. ie it doesnt try to tick over?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
if it doesn't do anything like mentioned above, try wacking the starter motor once...works on older cars...
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
the fuel pump doesn't work off of the starter motor does it? So the fuel pump not priming is quite significant here isn't it, rather than looking at the start motor?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
yeah but its not doing anything...no noise either...
so that would not make me look at fuel first.
If it was turning over and trying to start, but just not starting then I would say its either a fuel or ignition of the fuel problem. But the problem is before that even happens...
so I would say electrical power related
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
was just searching this problem, and saw a guy with cupra R 225hp leon that had similar problems. Also thought it was the ECU, but ended up being the Fuel Pump Relay...so check that too
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
The clicking sound does sound like a relay to be honest. Can anyone tell me which ones are the fuel and ignition relays??
I'll check the ecu for water as well.
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Reuvers, Which relay is the fuel pump relay so i can check it?
Hmmm it's a new coolant temp sensor only a few months old, only done 7 miles:headhurt: But i'll go check it out as well. Cheers Myki
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
but the clicking is coming from the engine, and the relay is under the dash if I am not mistaking...
Rapid clicking normally means the starter motor but baz said hes tried jump starting it which would work even if the starter motor was gone. Could be the injectors clicking as there trying to fire it up
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Right lads, here are my relays. Which one is the fuel pump?/
Dec 3, 2007
2,475
cardiff
actually come to think about it. My car did this back last year and if i remember correctly it was the temp sensor. It sometimes wouldn't start. But after a few attempts it did.
