car keeps revving on overrun
Keiran1995
17
Cars started to have a little problem. When giving it stick and you let off and it just keeps revving to about 6 and a half k then drops back off.
Would like to know where to start looking, or any one else had previous problems.
Cheers in advance.
Keiran1995
17
Where that situated? It only seems to do it in first. Although in second and third the revs stay at what ever I let off then eventually drop.
the parrot
113
Ireland
thats just above the clutch pedal. you have to take the covers off
yea they should drop almost instantly to an extent.
but the over rev sounds like the
Keiran1995
17
Spot on cheers I'll take a look tomorrow. To an extent yeah I don't expect them to drop to idle revs instantly but I do expect then to gradually go down instead of staying where I let off or even revving to the limiter on occasions.
Keiran1995
17
Sorted now. Turned out to be the clutch pressure switch like you said. Took it off, cleaned it up. Blew all the crap out the connections now its spot on.
siandcian
57
I have same problem in 2nd mainly if i let it come on boost then go to change the revs shoot up. Ill give this a try. Can they be cleaned or do they need replacing?
SWANSWAY CUPRA Dealership
