car keeps cutting out
Jan 6, 2009
1,102
sunny falmouth
alright peeps my car randomly keeps cuttin out it happens when i rev it and just let the revs drop it then cuts out it also happens when driving i have to wait to the last moment to dip my clutch or it cuts out and its starting to get real annoying rang up my local vag garage and they said my throttle body needs cleaning and something resettin threw vag com does this sound right:confused: has any one had this problem or had it done thanks
Ethan040
60
Nottingham
What engine is it? if its a 1.4 id say clean the throttle body out then get a throttle body alignment/reset with vagcom theres loads of guides on how to do a TBA on the net using vagcom i had to do it to my old polo its dead easy if not i had it done before that at a garage for £30.
Defacto
mine's being doing that for a while, and i've also heard of others. If you do a search you'll find all sort of explanations.
At first I did all the standard suggestions (throttle body clean/alignment, change the oil and asked around a bit). Mine only does the cutting out if i've left it for a couple of days without use.
Got my hands on a ebay cable last week, with the free version of vagcom. For the life of me I havent been able to work it, jsust says something about interface not recognised. Don't want to fork out the 60 they charge to vagcom'it up around here.
I'm guessing it's most likely to be one of fthe sensors, and it would be an easy fix as well, once you know wtf is actually going wrong
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
Sounds like its your t/b or possibly your d/v sticking open or seal gone if its a 007p when was the last time you serviced it.?
Jan 6, 2009
1,102
sunny falmouth
i aint fot a forge 007p dv iv got a weird one which was on car already its not a recurculating one but it was fine on car yea iv been told its the t/b needs cleaning then summin resetting through vag com
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
These cars are designed to run on reserc d/v if its a fully atmos then that will cause problems itself...if its a dual port like the split-r then its proberly not set up correct. Id look at changing it for the correct d/v fitment asap.
Jan 6, 2009
1,102
sunny falmouth
cheers mate got a forge 007p and my car feels so much better for it
Cuprajohn
The Cupra Kidd
Feb 24, 2007
332
Isle of Lewis
i searched for an answer on this ages ago, an was told it was to do with the d/v being to close to the maf summit like that wrong tip i think. ill hunt for the post.
