Car gets a bit wavey at High Speed?
virdi
892
Middlesex
Hi all,
I recently had a chance to run my car (LCR - IHI Converted) on a Private Test Track ;)
....at about 120+ the steering seems to get very shakey etc....
What should I look at?
...also - powering out of corners - I can never get the power down, I seem to get this funny vibration/rumble if I power out of the corner..? is this the inside wheel not getting grip? or the ESP? or the Diff?
JamJay
California Bound
The vibration could always be wheel hop. I get this when pulling away in mine, it has too much torque. I am in the process of getting an uprated dog-bone mount to see if this helps things. Have you upgraded any of your mounting?
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Rumble? like ABS?
I suspect ESP is kicking in, is the yellow light on the dash flickering?
Two options to help;-
- lowered uprated suspension and anti-roll bars
- Quaife or Peloquin type ATB Diff
either option will cost £1000 to £1500 if done right incl fitting
dippy4000
going faster
Feb 14, 2009
157
Kent
It might sound like a very basic answer but i had the problem once getting 110 in my previous car, turned out the wheel balance on just 1 wheel was just slightly out after having a tyre change 3 months prior, but never went fast enough to know untill that day!
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
another thing to check is the plastic trim under the bumper, it plays a big part in stability at high speed.
virdi
892
Middlesex
With ARBs - The thicker they are... the more stiffer they are?
Hence - The more the body roll is reduced?
is that how it works?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
and get all 4 wheel's balanced and ask them if any were out by 5/10g? i would guess
