Car dies while driving
Jul 13, 2024
Hello, so I have a Seat Toledo mk2 2001 petrol engine 1.6 16v (code name AUS) converted to LPG with Lovato's kit SmartExR and I came across this problem while having a big trip for about 3 hours using only LPG. The car was driving fine around 130-140 km/h until we tried to make a stop. I was in 5th gear with around 3k rpms and I put it in neutral then the car suddenly died while running instead of staying in idle. I pulled over quickly and tried to turn it back on and it did yet it died once again after some seconds. After that nothing I tried turning it back on but no luck. My insurance came and took the car with a trailer. About 1-2 hours after they called me and told me that the car started up with no problem so the next day I picked it up and made a 2-hour long trip with only petrol and everything was fine. Any idea what might cause that issue?
mty12345
4,107
680
bristol
Crank position sensor or fuel pump/ pump relay would be my best guess, but could be other things. Any fault codes stored?
Reactions: JimScott
Jul 13, 2024
Nope, nothing we even checked the lpg system and everything seems to be fine. Since that day the car is running normally. It has a problem with rough idle but it doesn't die when it's on idle, only the rpms are not that stable.Idk if those 2 are related.
Jul 13, 2024
We found the problem causing the car to die for anyone wondering. The car is burning a lot of oil around 2 L for 3000 kilometers and some of it escapes and damages the spark plugs causing them to fail. That's why when the car cool down it started again
