Cant get radio reception
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
you live in wales ? :) nah just messing, along as you reconnected the ariel then there shouldnt be a problem, swap you standard one back in and if that picks up radio. its the stereo..
Stu_HR
Odd Member
Jun 9, 2005
293
When I fitted my alpine the arial lead kept pulling out of the socket when the head unit was pushed fully into place. Eventually the centre core of the coax broke off the connector. (Admittedly the cable may have been damaged when some :censored: in Luton smashed the passenger window & ripped out my Sony unit!)
:mad:
I'd briefly reconnect an old head unit just to make sure the aerial cable & connector are OK before going any further. One other failure I've had is water getting into the base of the beesting aerial which frags the built in amp unit.
bezza
50
most Seats require a ariel booster.
you can buy them from your local halfords about 6 quid, which is a universal booster. this usually does the job and gets most popular stations, however is this still doesnt work, you will have to buy the seat car specific booster (usually ordered in depending on halfords store size) bout 8ish quid.
Stu_HR
Odd Member
Jun 9, 2005
293
Fitted the Beesting myself & made sure it was watertight with plenty of silicon sealant! IIRC the aerial was @ £30 from Seat.
pinsnpies
104
Bangor North Wales Uk
Thanks for the info. I will go into halfords today.
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
I really do doubt its your radio, i have had Panasonic JVC and SEAT headunits in my cars and none of them have ever needed an aerial amplifier. It is quite common for the beestings to go especially at this time of year due to the poor weather.
If your car is a GTI or Cupra then there should be a pre-fitted cd changer cable so if your reverting back to a SEAT headunit go for the Grundig one with a 6 CD autochanger on it
pinsnpies
104
I might get a new aerial on ebay. Then again its simply not a case of easy installation. You have to fiddle about with long screwdrivers and the like [:@]
pinsnpies
104
Nah its the blue wire on my leg. I plugged the copper wire from the end of that into my stereo and I get radio although is not very good reception. I get radio 1 so thats about it really.
studioeng
R.I.P. SXE. Hello Salsa!!
Feb 12, 2007
76
Dorset
www.byattsystems.co.uk
Sorry to bring up an old thread; but I'm having alittle problem with my radio reception. On my car; when I bought it, it has some horrible aftermarket headunit (a cheap kenwood) its got a standard DIN type aerial cable; although some monkey decided to cut the end off.
I've put a plug back on the cable, but I'm getting a very poor signal, if anything at all; does this need the fabled aerial amplifier or is there something I'm missing??
bezza
50
Er the Aerial is a co-ax cable, requires soldering. if its not done "propper" you will get crap reception.
needs to be 100% spot on!
