Can someone help with my polo turbo fault codes??
str8ballin
211
Hi I have finally got my car running now but needs re-mapping due to k04 upgrade (AYP block).
I get these fault codes, and Im not sure how to fix them:confused::cry:
Any help will be soo much appreciated!!
Control Module Part Number: 6K0 906 032 AA
Component and/or Version: 1.8L 20VT EU3 0002
Software Coding: 10500
Work Shop Code: WSC 00000
8 Faults Found:
18087 - EPC Warning Lamp (K132) Circuit: Open
P1679 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-00 - -
18099 - Malfunction Indication Light (K83): Open Circuit
P1691 - 35-00 - -
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
and a few others after i cleared the codes and got the exhaust fitted...
Thursday,23,August,2007,17:12:29
VAG-COM Version: Release 607.3-UD
6 Faults Found:
P1118 - 35-00 - -
P1691 - 35-00 - -
P1679 - 35-00 - -
P1114 - 35-00 - -
P0140 - 35-00 - -
P0501 - 35-00 - -
Readiness: 0010 1101
str8ballin
211
all of them are present at the moment?
Hi there, yep all the codes are present!
I clear them but they come back again straight away.
The car seems to boost to 0.5bar at 2K so not sure if im hitting limp mode or not, I need the remap on saturday so I can drive the car properly, just want to makesure the car is ok before I get towed there and they say they cant do it due to faults!
Is my O2 sensor faulty??
Please help! ! ! :cry:
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
I believe Lambda Sensor is faulty. B1 - S2 is the post CAT Lamda Sensor. Open circuit/Resistance too high... They are signs of it going wrong.
With regards to the Vehicle Speed sensor and the EPC warning light. They sound like loose connections to me. Not something that will enduce limp mode I wouldn't have thought.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Well my car has same fault B1: S2 stating internal resistance too high. THis is the post lambda sensor. My car still pulls very well!
You have also a epc fault which could be the issue!
Ibiza.Coupe
24
Tel Aviv
UP
same car same engine code (AYP) same problem
18100 - Malfunction Indication Light (K83): Short to Ground
P1692 - 35-10 - - - Intermittent
i know that is was long time ago
did u slove problem or anyone else?
