Hi I have finally got my car running now but needs re-mapping due to k04 upgrade (AYP block).
I get these fault codes, and Im not sure how to fix them
Any help will be soo much appreciated!!
Control Module Part Number: 6K0 906 032 AA
Component and/or Version: 1.8L 20VT EU3 0002
Software Coding: 10500
Work Shop Code: WSC 00000
8 Faults Found:
18087 - EPC Warning Lamp (K132) Circuit: Open
P1679 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-00 - -
18099 - Malfunction Indication Light (K83): Open Circuit
P1691 - 35-00 - -
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
and a few others after i cleared the codes and got the exhaust fitted...
Thursday,23,August,2007,17:12:29
VAG-COM Version: Release 607.3-UD
6 Faults Found:
P1118 - 35-00 - -
P1691 - 35-00 - -
P1679 - 35-00 - -
P1114 - 35-00 - -
P0140 - 35-00 - -
P0501 - 35-00 - -
Readiness: 0010 1101
8 Faults Found:
P1118 - 35-00 - -
P1691 - 35-00 - -
P1114 - 35-00 - -
P0501 - 35-00 - -
P0140 - 35-00 - -
P0571 - 35-00 - -
6 Faults Found:
P1118 - 35-00 - -
P1691 - 35-00 - -
P1679 - 35-00 - -
P1114 - 35-00 - -
P0140 - 35-00 - -
P0501 - 35-00 - -
