cam belt
ba55ca5e
i drive a 2001 cupra T. just wondering at what mileage the cam belt should be done and has anyone had one go. If so at what mileage. any help would be greatly appreciated.:help:
ba55ca5e
mines 8 years old and has done 80000. I bought it at 70000 miles. it has a full service history but in the service book it doesnt say that its been changed.
ba55ca5e
jst booked it in to have it done. 275 pounds. bloody extortionate.[:@]
Cupra Ross
Breaks things............
May 15, 2005
1,379
Edinburgh, Scotland
£275 is pretty cheap. Its about 2.5-3.5 hours worth of Labour. I would suspect that the figure you have been quoted does not include a new waterpump or hydraulic tensioner damper (different from tensioner). You should really be replacing these also. £400 is not an unreasonable figure for a respected garage to charge for the job to be done properly.
If you're not replacing water pump and it fails (which is common on the 1.8T) it'll cost you the same again to repair that as the cambelt has to come off to replace the water pump. Bite the bullet and get it done properly. Pay one bill instead of a possible two.
ba55ca5e
thanks for the heads up. i will look into it. the garage that quoted me that figure was a seat garage in bury st edmunds.
Jun 26, 2008
1,299
Just round the corner.
Had mine done, around 80k. Advised that the you only change the water pump if it starts to fail.
DON'T RISK IT! Had a water pump fail on my Calibra Ecotec......£1500 to fix it.
Water pumps are around £45 - 60, for the little extra you have piece of mind. Plus it makes sense, that if the cambelt is off, to change the water pump as there rum off the same belt.
Make sure you tensioners and pulleys are changed too.
ba55ca5e
had a word to the lady holding the purse strings. think im gonna get the whole lot done. problem is it needs a service to. is gonna cost a fortune.
Cupra Ross
May 15, 2005
1,379
Edinburgh, Scotland
Where are you located? It'll be much cheaper to go to a specialist than it will be to have it done by a dealer. The various forum sponsor specialists will do a better job and charge you less than the dealer.
R69
313
West Midlands
Had mine done at MidlandVW a couple of weeks ago - £260 for parts, labour & VAT.
This included the cam belt, tensioning roller, relay roller, water pump (with metal impellor) and coolant replacement.
Send them an email & they'll sort you out, speak to a chap called Jody, knows his stuff!
Fixed price servicing is pretty good there too, I'll be taking mine there for all maintenance work.
They're based in Cannock.
Good luck mate, the feeling of peace of mind once it's done is more than worth what it costs! :)
ba55ca5e
i live in suffolk. if anyone could point me in the direction of a local garage that can do the job for cheaper it would be greatly appreciated
ba55ca5e
just had a right result. spoke to my brother who works for ford in colchester.
going to get parts and labour for £120. dont know why i didnt ask him in the first place.
cheers anyway
