ALTEA DUDE said:
Only managed to get 1 speaker in this morning. Cant tell a lot of difference so far, 3 versus 1 not very fair! Bit annoying that you cant attach all the speakers to the adapters in the house and then attach the adapter to the car last as once the speakers are attached, it blocks the holes needed to attach to the car.
On pulling off the speakers I was probably protecting my finger nails... on the one above, I did, mind you that's why it took me about two hours working out where everything was going first of all. I soldered the leads on in the house with my brother starring and saying I wouldn't solder and I said I prefer soldering.
So you then got the speaker with a big long lead on it. I pulled out the rubber grommet that holds the wire into the body of the car and threaded the wire back into the car and pushed the grommet back again. Follow ?. It's about nine months since I did that. I suspect that could be your issue that the cable comes forward from the speakers, into the body of the car behind the grommet and the plug is this side I think, hmmm.
So I reckon you need to get the cable behind the grommet then you are OK. Do disconnect the tweeters as well, they are crap.
I hope you get as good a sound with your Rainbow speakers as Infinity
. The headend is very good, it’s daft what the VW group do.
Yeah... I think this is it, the cable from the speakers comes back from the back behind the grommet then plugs into the speakers this side and the plug and socket is tucked away... I plead it's been too long...
