Hey guys, I went and saw a Tolly V5 today. Some good and some bad points, can't quite make up my mind about it, so decided to ask you what you think. I've put a 150 pound deposit on it, but might just walk away if you guys thinks it's a dud.
So the positive -- no corrosion, all panels seem straight, only one really minor scuff (that I could possibly touch up myself), interior seems fine as well. Most electrics seem to work (the ones I checked anyway). No noises or creaks from the suspension or at least I could not hear anything. Engine was pulling away fine, idles alright I think. The car was warmed up (well was running actually) though when I got there so that was something I was not too happy about. So the few things that got me worried:
1. Wet floor mats on the driver's side -- no surprise there. The seals on the front of the rear doors (the ones between the driver's door and the rear door below the window) seem to be the culprits as they are basically coming off -- do you guys think that changing those should fix it? How much was that again? Any good VAG specialists near Edinburgh?
2. There was a light on on the dash -- a yellow circle with 2 squares on each side what's that one about? Brakes? The rear discs seem to need replacing as they're quite "groovy" possibly the pads might be worn out.
3. The steering seems to be pulling so slightly to the left (well the roads on which I tested also seemed to have a bit of camber as well), like the natural position in which it would like to stay would be off by a couple of degrees, actually this is my main issue with the car? Is this serious, and would it be expensive to fix? I had a look underneath, and it seemed quite alright -- CV joints looked fine, could not see any leaking from anywhere (including shocks).
4. The sat nav voice also seemed alright but would break at times and sound horrendous for some time, and then be okay again. What's that about?
5. The fans up front were running when the aircon was on (or at least I think so), when the car would idle at temp they would turn on on high for a bit and then turn back to low, is that normal?
I'll add whatever I've forgotten once it comes to me, but that's I think the more important stuff. I am really desperate to get some feedback from you guys, as I kinda liked the car, but am not sure if I'll just end up spending too much money trying to fix up these small looking faults (which might turn into big faults
