Bulk Head
mALLA
116
Sussex
Anyone know where i can route a wire through to the cabin, preferably near the fuse box, other than the bonnet release cable?
Cheers, and where might i find it?
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
funnily enough theres a small mod needed to take a cable from the engine bay through directly to the fusebox, i used this route for my boost gauge, very easy to do and once you open the fuse box and move it to the side you can find the wire coming through easily.
mALLA
116
Sussex
thanks mate. yeah already used the bonnet release cable grommet hole with my boost pipe. didnt fancy ramming another wire into it, might damage the hose :D
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
trhe black box i tapped into doesnt house very much, you could reroute a few cables/pipes through it and because its raised, its more waterproof than other routes. i drilled using a 5mm bit so the 5mm piping fitted through wather tightly.
