It had to happen, it was all going so well.
I'm in the midst of changing a broken front coil spring, and the guide I was following (which is for the Ibiza) recommended removing the ABS sensor from the hub, as some hammering may need to happen. So off I went; a liberal application of some penetrating fluid, removed the stud, and gently prising up on the sensor until.....
it snapped :/ and its left the bulk of itself in the wheel hub/knuckle.
I'll have to get the residual part out. Could I get lucky and just go gently with a drill to remove the remainder? Or would I be better off taking off the entire hub/knuckle/brake carrier and go at it that way? I guess that the ring is in the hub on these.
(BTW- I was surprised to find that this car has no detachable caliper carrier; it's part of the hub/knuckle component. I think its the first time I've seen that)
tia
tk
tia
tk
