Brake pad sensor
dholdi
931
Preston
ta for the replies, I just thought there'd be one on either side :confused:
Previous cars I've had have had them on both sides. I guess the thinking is that both should wear at the same rate. Which they will as long as you keep your calipers maintained correctly.
D.K
LCR 225
Oct 24, 2007
6,408
se london
Mine only had a sensor on the near side.
If in the future you buy pads without the sensor's in them get yourself a female spade conneter and plug that into the wireing loom from the the car, this will join the wire's and turn off the light ;)
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
Just wanted to check that if I buy replacement pads for the rear does only one set need to have a sensor and the other without?
