Boost Problem - hesitation/juddering
dave_6
193
Essex
Boost Problem - judder (pics)(fixed-coil packs popped up)
Hi,
Only had the ibiza for a couple of weeks
2001 cupra
spec list
Jabbasport remap
K03s Custom FMIC
3" Blueflame 100cell race cat Downpipe leading to 2.75" Catback Scorpion, heatwrapped.
Aquamist set at 12psi.
4 recent coils and brand new spark plugs
Forge 007p DV
Ok, not had any boost problems until today, hadn't drove the car for 36 hours, started fine and drove for 10 minutes, didnt do any hard driving so all was fine, then went out and got petrol later on
99 ron stuff which i've always used since getting the car
got onto a national limit road, all well warmed up, boosted fine in 4th and 5th without problems
then later on dropped to 4th and boosted and it started to and then stuttered really badly, power started to come then totally stopped coming
tried again in 3rd gear and also 2nd gear, and it kept doing it, fine to about 10psi, and would shoot up to 20 but would stutter and judder and just wouldnt carry on
my aquamist comes in at 12psi, injection of methanol and distilled water, but i doubt its that blocked as i wouldnt have thought it would cause it to struggle that much, more a loss of power, rather than the total block of power kicking in which i'm getting
new to the car and the engine bay so I dont really know too well on what i need to look for etc
did a couple of searches but cant see much, most just suggest hooking up to vagcom, i'm in colchester in essex if anyones local and fancies helping
Dave
dave_6
193
Essex
Ok have driven more
all is fine, even at 15 boost its all fine
but assoon as you hit 20-22psi, thats it
it feels like your hitting a rev limiter, bouncing off of it and keep losing power, gaining it and hitting the limit, then dropping a bit again
coil pack???
I know they're common, very common, think the last owner even left me a spare
dave_6
193
Essex
Ok, have done some searchings, found one titled, coil packs popping up
went out to the car and this is what I found:
number 2, up highest, and also number 4 slightly up
so at a guess either came up from the heat, or sparkplugs being loose?
anyone else had this lately? or had it before
have now pushed them back in
pickie
222
strange my coil packs are doing the same, they keep popping out ?? and i too have the stuttering prop under heavy exceleration and high speed ~ 100Mph
havent gotten around to replacing coil packs and sparks so not sure if thats my prob yet :)
Nov 2, 2004
9,335
South Wales
Nothing to do with spark plugs making the coil packs pop out.
See bills post about cutting a V into the rubber on the coil pack shaft to stop them popping out.
dave_6
193
Essex
yea I saw the V in the rubber
spark plugs are pretty new, have read that the heat can make them pop up so the V cut in helps to release the pressure and so the coils dont pop up
will check the spark plugs are in tight enough, and then will probably cut the V in
has only done this once in the 2 weeks i've owned the car, and I need to have the bonnet open once a week anyway to check my aquamist is all topped up so its not a problem just checking they are seated properly
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
have you got a bigger turbo? just wondered why you stuck some exhaust wrap on the charge pipe? charge leaving the turbo will be so hot anyway that i wouldn't have thought it would make much difference tbh
bolt down coilpacks are the business, but just follow bills advice and that'll sort your problem
dave_6
193
Essex
I did indeed, off "flash" whos banned from here........
took the car out earlier, and now holds on full boost perfectly again
shame the sun hasn't been out for a while
needs a good polish, some pics, then i'll finally post up some pics and an introduction
dave_6
193
Essex
Lol, theyre my old coil packs as well and my old washer tank.
ah, so your the one to blame for my coils popping up then hey ;)
going to stick a spare coil in the boot as I guess some if not all of the ones in there might be fairly old
