Just had a rather large service on the Ibiza cupra. The car has felt a little slower recently (only a little) and the car's turbo did sound different. Was petrified it was the turbo on the way out.
Turns out I have a split boots pipe (not sure where). So this will more than likely be the source of the turbo sounding different.
Do you think the car will feel faster when I get it back? Will a split boost pipe effect performance much? I have no idea how long its been like this.
I'm also getting a Pipercross panel filter at the weekend. I’m looking forward to seeing if this will make the car feel any different.
Also got a slight oil leak to the intercooler. Can this be fixed or will it mean new intercooler in the long run?
EDIT: Also when at motorway speeds very rarely if I accelerate at around 2500-3000 rpm very gradually the turbo will cut out completely and go into limp mode. If I turn the car off and then back on again all is well. Is this a sign of boost leak? If so its been leaking for the last year.
