what is the name of that unit that you can remove and bypass that stops the dump valve releasing boost? i have a feeling that's what my car is doing. if it gets a bit hot, or i change gear too fast, the boost will drop from about 16psi to 8psi for a few seconds then shoot back up again. it does it in every gear sometimes, then 2 minutes later won;t do it at all, then will do it again?! v.frustrating when i'm trying to have a friendly play with something. i was having ago against a pulsar last night and held it at 40mph in 2nd, we both went for it and i was fine in 2nd and 3rd, then all of a sudden the boost dropped in 4th and then went up again after a few seconds. happened to my mates ibiza and he removed this box thing and now he says it hardly ever does it. is it n249 or something? could this be causing the problem? thanks
