boost gauge help??
mini_hammy
dirty wee ****er :D
Sep 7, 2008
118
tarbolton,Ayrshire
right bought a boost gauge and well am stuck lol
first pic is a thread but not sure where it goes
and the other is where u must put a vac hose of some kind
sorry about the bad pics but any help would be good??
cheers
Dec 3, 2007
2,475
cardiff
i dont know where the first goes as i have never seen one of those on a boost gauge. the second pic needs to be in a vac pipe coming off the throttle body!
what gauge is it?
Dec 3, 2007
2,475
cardiff
it looks like that pressure sensor has to be tapped into the inlet manifold. you have to drill it and then a tap and die set to correct the thread. then tap it in.
Dec 3, 2007
2,475
cardiff
yeah send it back and get a new one. that is alot of work unless you wanna waste the time.
in order to do it properly.
place gauge.
wire in.
run wires
remove inlet manifold
pilot hole
bore to correct size
tap it.
fit it
refit inlet manifold and check working
(fail)
mini_hammy
dirty wee ****er :D
Sep 7, 2008
118
tarbolton,Ayrshire
i bought them off a guy a know very cheap still in the boxes wrapped up
mite jst try and sell them on they are £288 for both i bought..thats wen brand new tho
so should be able to shift them for a decent price lol
Dec 3, 2007
2,475
cardiff
you can buy cheap gauges than that. mine are about £700-£900 for the set and they are not even that hard to fit. thats weird that set up.
Dec 3, 2007
2,475
cardiff
however i believe the accuracy of your gauge maybe amazing du to the way it collects the date so to be honest i dont think it will be that bad if you decided to run it.
