Anyone run one?
I'm tempted to try one out to see if i can get a little more out of my turbo at the top end of the rpm as i'm seeing under 70% WG duty.
Also what is the deviation on boost, is there a rough limit of percentage you can go over and under the requested boost?
Would be nice to be able to drop the boost in first gear and raise mid-top end in higher gears.
