Boost Controllers
Nov 2, 2004
9,335
South Wales
Anyone run one?
I'm tempted to try one out to see if i can get a little more out of my turbo at the top end of the rpm as i'm seeing under 70% WG duty.
Also what is the deviation on boost, is there a rough limit of percentage you can go over and under the requested boost?
Would be nice to be able to drop the boost in first gear and raise mid-top end in higher gears.
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
i have spoke to jabba about this on running a ko3/ko3s
they say that it isnt worth fitting one when running these turbos only on bigger ones
carlisle pete
649
i run the jabba one!! just a little manual one that sits neatly on ya dash!! think its 100 quid or so
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
thats the one they can put it anyware you want
i was going for one of those but told me it wouldnt be worth it on ko3/ko3s
said try use your foot betta
Nov 2, 2004
9,335
South Wales
I'd like to use it when i get my turbo setup sorted as well which will be on Revo Stage 3, so i guess the second part of the question of the deviation is quite important.
beattie17
1,353
Perth
Ive heard good things about apexi avcr. Ive still yet to fit mine, but recon it should cure my boost, im dropping from 1.4bar to 1.2bar up the rev range.
BIG_Y
95
Israel
i use greddy PRofec B-Spec2 on my ibiza K03s,and its work very good on tht turbo.
i have the greddy more then 3 years on my car.
low boost set to 0.9 bar,hi boost set to 1.48 bar and hold 1.25 til 6300 rpm.
Feb 1, 2007
1,293
gloucester
my mate has a jabba one of my old car if u want it phil , u can have it for free if u want it , hooch had a apexi boost controller on his old k04 , think he ended up taking it out in the end , he is the man to ask about them
Feb 1, 2007
1,293
gloucester
its just a switch , that you have got to plum into the ecu somehow , i took it of my old cupra r ibiza as i thought that was what was causing it not to boost properly , but it wasnt , its the one jabba charge £100 for , its nothing like an apexi one , its just a small black box with a knob on it
Feb 1, 2007
1,293
gloucester
you would be best of with an apexi one , send bill a pm , i think he is running one in his car , hooch will also tell you if they are any good , i think he ended up ripping his out as it was causing problems , not 100% sure , give him a pm , thats why i have always stayed away from them , as i never seem to hear anything good about them ...
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
why you binning it matt ??
Because i always wanted the car to control its own boost levels, JBS said they will be mapping it with N75.
Just means 1 less thing to worry about.
Dont get me wrong, its a great bi of kit that does the job very well, And Beattie, yes it will eliminate the boost drop as your GT2X held 1.4 Bar on mine all the way to redline.
It also means i can free up some space inside for oil pressure gauge and boost gauge.
Also the Apexi can be set to deliver different boost pressures in different gears to reduce wheelspin which is handy.
9,335
South Wales
Matt, give me a shout if you want to sell it. ;)
I might see if i can borrow one to try it out, at least i have the requested figures on vag com so i can set it up using those.
