Bonnet lining????
1835harri
The legend
May 21, 2007
361
Llanelli, SW Wales
Hey all, i was thinking about doing my engine up, and first thing i noticed in other poeples engines were that the engine cover had been taken off and the lining that is fixing on the underside of the bonnet. Is this safe??
Obviously, they are both there for a reason and was wodnering what the technical reasons against taking it out were and is its worth it.
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
engine cover maybe keeps a bit of dust and dirt off your engine top, but has no real adverse effects. i've had mine off for over a year
the bonnet insulation is soundproofing to a degree but does keep heat in the engine. i will take mine off in summer and perhaps replace it in winter
porki
Mull Fember
Jul 26, 2007
105
Tunbridge Wells - Kent
it's all extra weight, get rid of it!!
seriously it's just sound deadening, if you do remove it you'll hear things more clearly so don't get freaked out by all the extra little noises!
1835harri
The legend
May 21, 2007
361
Llanelli, SW Wales
AHH OK. was slightly worried that it might catch fire or something. i knew it kept the heat in but even if you dont replace it in the winter, will it have trouble starting??
Makes the engine louder?? in a bad way or a good way.
porki
Mull Fember
Jul 26, 2007
105
in a way that you just haven't heard before... hear buzzings, whinings, clicks, alsorts!! nothing new it'll just now be audible ... maybe, it might be that you still don't hear stuff but just don't crap yourself if you do!
1835harri
The legend
May 21, 2007
361
Llanelli, SW Wales
lol, gonna take it off this afternoon adn see what its like when i go for a spin later.
Think it will look better without it anyway
Thanks all for your advice so far guys.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
My car is kept outside. I removed the bonnet lining early last year.
I've opened my bonnet a couple of times in the last few weeks when the car is cold to find the underside of the bonnet absolutely dripping with water.........
(Condensing on the cold surface).
JamJay
California Bound
Linings to have a horrid tendancy to trap moisture between them and the bonnet so in a few years (im talking over 10yrs, it's a slow process) you may see some rust surfacing on the top side of the bonnet where the welds are.
D.K
LCR 225
Oct 24, 2007
6,408
se london
It should'nt discolour Brett, Just keep polishing it and it will stay bright.
I'v taken my soundproofing out and mine's fine aswell.
D.K
LCR 225
Oct 24, 2007
6,408
se london
Mine was driping wet when I looked at the weekend, The charge pipe should be Ok as it's stainless steel.
D.K
LCR 225
Oct 24, 2007
6,408
se london
Mine's been off for a while and I'v had no problem's.
You will get a bit of steam off it when it rain's but this is nothing to worry about.
