to start off you receive the handset,
connect this to the cart via the OBD which is behind the plastic trim to the right of the steering wheel.
the unit will then offer a series of commands, ignition off - yes then on - yes etc, the unit then copies the current map.
You then connet the device to your PC and it send the map to superchips. Within a few hours ( during working hours) Superchips select the correct map for your car, you then receive a text and email telling you its ready.
Connect the device to the computer and it loads the file, disconnect the handset and then connect back to the OBD in the car,
Follow the on screen instuctions .... and then your mapped now go for a drive !!
I think I have some pictures somewhere so will post them later if i can find them.
