Blown HU fuse
nickylewis
Got Pioneer DEH-3730MP fitted, and after 10mins the fuse blew.
Changed the fuse, and all is well (at the moment). Is this likely to happen again?
Thanks.
gazjones
i had a problem when installing my head unit worked for tem mins then went and needed to chancge the wiring around but this affected the car fuses not the head unit fuse. just see how it goes could have just gone normally.
nickylewis
Got it changed and its fine.
Thanks.
Diablo559
Diablo
Mar 1, 2005
218
N.Ireland
the fuse in your head unit was prob a 15 0r 20 amp and the fuse in the standard radio is usually about 5 0r 10 amp as soon as you turn up the after market radio bang cause of the smaller rated fuse had to fix a car a while back and that was the problem
