Long time no post, sorry! Does anyone still remember me?
Hopefully someone might have some advice... my 10 reg 1.6CR Ecomotive SE has suddenly (since yesterday evening) decided not to blow any air through the vents, regardless of whether it's on auto or any manual fan setting, including max. I have the climatronic a/c.
It wasn't making any funny noises or anything different to normal - I just noticed it was colder than usual and when I turned the temp up, the little red lights for the fan ramped up, but nothing was coming from the vents.
When I put the windscreen demist on (or forward only, feet only, etc), I can hear flaps/stuff moving about as normal, but no breeze out of the vents and no fan noise.
I think the heat is still working - I can feel slight warmth out of the vents when on normal settings and it actually feels quite warm with my hand on the vents on high temp settings especially on the "forward only" mode.
Naturally I've done a search on here - my first port of call for any Leon queries, of course - and found some useful tips from Techie, Coggie, TimSarf and others. So I spent the afternoon freezing my nads off on the drive, trying to fix it. This is what I've tried so far:
1. Took off the panel on the end of the dash next to the steering column, and checked all the fuses - they all look fine.
2. Ditto the fuses in the engine bay in the box next to the battery (once I finally worked out how to open it!) - they looked fine too.
3. Unscrewed and removed the plastic panel under the glovebox and removed the blower fan. This involved a certain amount of mumbled swearing as it was a devil to get it to twist out and my legs were in the snow in the mean time! Couldn't see any sign of water/corrosion on any screws or connectors. The fan itself seemed to turn freely when I gently spun it with my fingers - didn't seem stuck or stiff or anything like that.
When I put everything back together, I was hoping that I might have fixed it by wiggling/re-attaching some loose connector or fuse... but still nought from the blower.
Does anyone have any other ideas for things to try please?
I don't fancy being without a blower in this weather for long, so fear a trip to the dealer might be needed, dang it.
Needless to say, with murphy's law being what it is, the car is now out of warranty - I've done almost 70k miles in it. I've always taken it to the dealer for servicing and have Seat Insurance too, so might see it they'll help towards any cost as a "goodwill gesture" or whatever they call it. Worth a shot or am I dreaming?
