Right, so I have a trackday at castle Combe booked on Friday. Not gonna go mad, it's more of a social thing with friends and tbh it's a little bit of an anti climax after the nurburgring.
One thing that was apparent at the 'Ring was that it took a lot to get the old girl turned in to the corner. Cue a rear anti roll bar. Phoned awesome, they didn't have the whiteline in stock but offered a pretty sweet deal on a neuspeed 28 mm. Because I don't think I'm gonna uprate the front anti roll bar I thought it may be too much. Phoned DPM, had one in stock, phoned them in the afternoon, the damn thing was delivered next morning!
Off work today so fitted it.
Been for a very brief drive, I had it on the middle setting and the difference is pretty big! May be too much though. I'm gonna leave it for now until I get a decent drive and see how it goes, I can slacken it if needed.
The next thing was brakes. The ds2500s are good but I had a bit of a pad pick up
problem after the ring. Some gentle driving seems to have sorted it but I know Combe will be harder on brakes. Done some research and the rear pads from a volvo S60R are the same pads for our front brembos. The castle Combe trackday is with a bunch of volvo owners and I happen to know someone selling some carbotech XP10s. Result! They also had more meat then the ds2500s that have done one ring trip and maybe 3k road miles. Result!
This next one is interesting and I've not seen it done on a leon.
Brake cooling. I thought of getting some brake ducting, route it through from the foglights and cable tie it somewhere but I wasn't sure of how reliably I could get something like that to fit and stay there for however long it needed to.
I found that some audi TT owners have fitted the brake ducts from the TT RS. Having a look online I also found that these TT RS ducts would not only fit the mk2 TT but also the mk1. And having read that the LCR has the same wishbones as the TT I thought, let's take a risk and see.
The hole is already there on the wishbone but with a very small amount of cutting with the dremel to avoid the drop link it fits!
Theres a spacer that comes with it, shown on the left for comparison. I cut that in half and fitted both ends, hard to explain but a pic always helps.
The other half fit underneath. The plastics flexible so I suppose it could have fitted without.
How the air will hit it underneath. Love the fact that it's an OEM mod.
Obviously it doesn't stick out quite as much as the pic shows, the cars angled up and the cameras low but you get a decent idea.
