Bit of help - mk2 16v GTI
mcchriswood
98
Hi guys.
Just looking for a bit of help really.
How much should i be looking to pay for a new cambelt supplied and fitted?
How much for clutch supplied and fitted?
And what stud pattern do the wheels have?? is it 4x100??
Im having awful trouble recently getting my car into 1st gear and sometimes reverse.
Also its REAL hard to pull away in as it feels like the clutch pedal comes up in sort of 2 judders so it either creeps away or i let the clutch off and it bounces along the road (if that makes sense) so im guessing its clutch problem.
Thanks guys
Chrissy
j.cavo
8 valves of pure power
Aug 6, 2009
229
Liverpool
Hi guys.
Thanks guys
Chrissy
the clutch issue is just that its a high clutch its just getting the hang of it really its just so fine between pulling of smooth and jerking everywhere
mcchriswood
98
It cant be that surely??
Ive had 9 cars and drive numerous vehicles on a daily basis.
Its like the pedal won't come up smoothly ie 2 steps and i cant get the pedal ebtween the 2 steps (ie where i need to get it)
Chrissy
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
check the pedal box is secure above the pedal on operation habit of breaking and causing problems crunching into gear but the cable is an adaption to a hydraulic converted box so they do have a low/high quick switchover feel to them
if you haven't got history or changed cable yet i can reccomend it considering that they are heavy standard mind
mcchriswood
98
sorry whats that cable then??
Something to do with the clutch.
No hjistory as i just bought it as a nippy cheap run around. (400 quid)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ye clutch cable
most cars have one around 3ft but ibiza one is 6ft+ as it's a conversion from Golf parts so not the best design sadly
new is a must to be honest and go from there
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
as said above though check the pedal box for movement as the cable's get so stiff they will break the mountings off the side
ye they are that bad :)
mcchriswood
98
how exactly do i check the pedal box then??
as you can tell...i dont deal with mechanics lol
mcchriswood
98
on a note not so bad :
the drivers side window isn't working and im baffled as to why...
and the abs light constantly stays on :|
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
winder mech's are common fault for cables and motor's iirc gsf do a cheap replacement
abs light on means there is a fault somewhere, you'll need vag-com or similar diagnostic software to find out what the issue is but mainly sensors and/or wiring to them
to check the pedal box remove the drivers side glove box and shine a torch up from the pedal, where the cable comes through the bracket just make sure that isn't moving/split or creaking, watching it as someone pedals is easier
here's a thread worth reading about mk2's but be warned it will put you off in places :p
http://www.seatcupra.net/forums/showthread.php?t=157494
mcchriswood
98
funny that ive just been reading that. Got too page 6 and same things started too come up so thought i would call it a night
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
always said that a mk2 should have at least one thing wrong with it at all times, if it doesn't then look out as it soon will
mcchriswood
98
you dont know the part number on gsf by any chance do you.
Just had aquick look and can only see window switch :z
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Damn their website system has gone to crap lately, sorry not looked online for a while, mind you looks like no one else did either :)
give ya local branch a call should see you alright
mcchriswood
98
great thanks flapper.
Just bought a new bonnet also as mine was a heap so i attempted ratting it which turned out ok although i dont like the look.
Its blue (turquoisey) however i think it will go well with my silver (sort of a turquoise blue)
do you know a complete average weight and size without having to go and look??
if not ill go measure up and remove and weigh it
(i need it for delivery)
Chris
j.cavo
Aug 6, 2009
229
Liverpool
nice 1 flapper i was thinkin pedal box.
sorry m8 didnt think you meant the pedal was jerky thought you were talking about the take off from the clutch as most mk2 owners will tell you its a fine art using the clutch
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
like the sound of ratting :) need some pics
saying that weight wise not a clue btu have a feeling someone was asking a couple of nights ago
agggh where is it !!!
