Bit of an Exhaust pickle
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
2- Bore size (mk2 16v/mk3 20vt same bore 55.5mm) whereas as your 1.8 is 50mm iirc so will need a adapter to fit
Just gonna mention that on msn to you, before you went :doh:
The pipe on the cat (going to the centre section) is going to be the standard bore, as flaper mentioned!!! :D
Dave_R
Sep 20, 2004
3,666
South Wales
don't be bent.......... get rid of it :)
You need to know what bore it is, you may need a sleeve to increase the size to the mk3 system
