Big thanks to Ruddmister and DannyK
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
After years of thinking about it I finally changed brakes and pads on my LCR over the last two days
All in all it took me 4 hours to do fronts and 2 1/2 hours to do the rear. This timings will be cut dramatically the next time I do it, cause I put copperslip on the threads this time, unlike the previous garages.
Looking back this was well easy and next time I think I'll be challanging the RAC teams:)
Ruds guide is spot on for the fronts. The rears are very very easy, probably take 3 hours in total next time. The stuff I bought to do the job cost no more than what it would have cost to get a garage to do it so next time it'll be for free.
If you've thought about it and have a mechanical knowledge or even can just follow guides then go for it, its a great sense of achievement:):)
Must have tools;
- Wind back tool for rear pistons
- 13, 15 and 17 mm spanner
- Philips screw driver
- Wire brush, copper slip, WD40
- Pry bar and hammer (a must in any job)
- Jack and axel stands
- Oh and cold chisle to get the disc screw out when you round it (or in my case when the garage that did the job before you round it[:@]:censored:)
Cupra_Clark
81
I have the EBC discs on mine just now with 2500 pads and they are well and truly warped, i've hardly even given the car much stick under braking on this set up either to be honest so i'm a bit disapointed as a few people had recommended these discs to me, gonna go back to brembo next month i think...
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
I'd go bad to EBC about this, these are marketed as race discs, if they canna take road punishment then how cab they take race punishment??
You 100% they are warped??
Have you got the Ultimax discs or the dimpled and slotted discs?
http://www.brakes4u.co.uk/products.asp?id=16028
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
thats not good at all!
complain to them asap! they should send you out a replacement pair of discs!
