Best Re-Map
tubz_cupra
hi everyone i need a good re-map to beat my showing off mate in his mk4 astra gsi z20let
he only just beats me but i won't to leave him miles behind wheres the best place to go for the best power whats the most your can get out of 1.8 20v t cupra 180 bhp and whats a safe bhp to go to someone said don't go past 260bhp with the engine being standed with no internal upgrades cheers dave
MrTurner
55
A standard re-map will take you to 210bhp ish. I've used R+tech in hinckly, very pleased.
You can go to 320-350 on standard internals. However, that will require big turbo, injectors, TIP, manifold, FMIC, full exhaust and custom mapping etc etc (and will cost the thick end of £4k)
On a 180 cupra the max you'll get out the turbo is 235-240 depending on dyno lottery. For that you'll need a stage 2 map, which requires a FMIC, TIP, induction mods and full turbo exhaust as a minimum.
You can get around 205-210 from a generic stage one map on a standard car
Edit: Can't go wrong with p-torque
nicksxjr
Revo....whiplash!
Jul 24, 2009
254
Somerset, taunton
Standard Power (Bhp) 180
Modified Power (Bhp) 225
Standard Torque (lb/ft) 174
Modified Torque (lb/ft) 217
There is no stage 2 quotes just that they offer stage 2 & 3
dg-1984
254
Glasgow'ish
No think he is saying there is a price for the stage 1, and it only says on the site they offer a stage 2 and 3 but no prices listed.
Mar 29, 2007
1,207
Berkshire
Rather than just peak figures which don't tell you everything, what kind of drive are you after - smoother and revvier or a big turbo shove?
JamJay
California Bound
^ that would be for me! :)
It can be a handful and concentration needs to snap in fast as you're catching distant objects extremely quickly but very fun. Driving normally, 1/2 throttle etc, it's quite sedate and comfortable, in fact not too different to a standard car other than the revs climb more smoothly. That's an AMD map I'm referring to by the way, I hear it's alot like REVO but I can't say for sure.
deedaskrh
115
St Helens
does anyone know apr remaps?
i have an LCR with a stage 2 Apr remap with all the bits youd expect to have bolted on with a stage 2, the last time i had it on the rollers it made 268bhp im just wondering if that sounds right?
it had the ecu reset as i had to have a recond turbo fitted.
should i be seeing more?
