baiely dump valve?
Pyro
hello 9is the bailey dump valve good to put on the 20v turbo? iv got a 007 forge on there but not that loud but iv been told that the bailey is no good for the enguine is this true?
Cupra Ross
Breaks things............
May 15, 2005
1,379
Edinburgh, Scotland
This has been covered many many times mate. The 1.8T runs a metered air system that is designed to have a recirculating (non whooshy) diverter valve, ie. it dumps boost air from the charge pipe back to the turbo intake pipe on the intake side of the system instead of out to the atmosphere. Running an atmospheric dump valve like a Bailey will make the system think that you have an air leak and it won't be happy.
If you want more dump noise, fit an open cone induction kit or a cold air induction kit. I have a Carbonio CAI and the Forge 007P sounds almost as loud as a Jap atmospheric dump valve through it. I've fitted the valve in reverse and it gives a nice loud chiiiiiiiiiiirp.
Pyro
wiked thanks man sorry bout not searching didnt really think to
Pyro
No problem Sam. There's lots of stuff there on it, you just have to wade through about 100 threads to get the full jist of it. I'm no expert but like to help if I can.
so far you've posted on pretty much every post I've read lol and there all technical answers so ill be keeping that in mind :) lol
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
take your bonnet lining off to hear it more, also do you run oem airbox.. if so run open cone induction and it will be louder as the boost recircs through the open cone
GREY 225
Jim R
Oct 15, 2006
445
You can get a recirculating bailey if you want to, not much different to forge though. Some have said that the bailey is louder than the forge, but as they both do same job i dont see how, getting a cone filter will make it much louder.
