Aux air pump
kieran_cupra
Yellow n Black works!!!!
Apr 15, 2006
403
Nottingham
hi all ,when i turn my cupra on i usually here a pump runing for roughly a min (when engine running), sounds quite loud, like a induction kit kind of noise then it goes off.
But the past few mornings i havnt heard it???
Anyone got any ideas, as im confussed
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
i have that noise too its the fuel pump priming the engine, i have LCR btw but should be the same
Tallpaul
821
Your fuel pump should prime when you open the door before you've even started the engine.
What's the point in it priming after the engine is running, fuel will already be pumping!
The noise is the aux air pump.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
fuel pump primes when u turn the dash lights on..it goes 'errrrrrrrrr'
the secondary airinjection pump/aux air pump is on when the engine is first running. it does sound really loud, the pipe off the airbox (that u stick a breather filter on when u get an induction kit) is usually where the noise comes from.
i found after adding the larger bore downpipe, it got even louder and sounds shite
Tallpaul
821
On my MY02 Leon Cupra the fuel pump primed when you opened the drivers door, before the key is anywhere near the ignition. I believe it is the same for al 1.8T Leons.
acidstrato
Dec 9, 2004
5,942
well this is an ibiza Q
still i would never have thought the leon was that sophisticated...yet also stupid cos it would prep for ignition even if you had just left something in the car and went to get it? :shrug:
dunno but even though its not the issue...the fuel pump primes with the key in the ibiza
Tallpaul
821
It's not exactly a sophisticated feature, in fact most modern cars have it. After all if you just turn the key straight to start then the fuel pump doesn't get a chance to prime fully so you may get a laboured ignition.
I've read articles critisising the feature because if you accidentaly filled a petrol with diesel then the whole fuel system can be contaminated without even starting the car.
