autometer boost gauge Q?
Oct 12, 2005
1,013
Hi...do the autometer boost gauges from apex come with a screw type T piece to tap into the boost hose with?
Balf2k
208
South East Kent
Yes they do
I got mine from Apex mate and yes, it comes with T piece and 6 foot of nylon tubing. The T piece is the right size to tap into the fuel pressure regulator as I done with mine. Looked a little small for the DV install. Gauge works fine (only fitted mine today :))
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
if you dont get one of the threaded adaptors , try demontweeks or one of the gauge manufactureres ,the threaded nipple for my gauge came in the gauge kit (defi)
Oct 12, 2005
1,013
I have been told by jbs that i need a metal t piece to fit the gauge to a DIESEL. Anyone know where i can get this from and what size. Thanks
Oct 12, 2005
1,013
I dont suppose you no which one on demon tweaks i would need. I have had a look but id nt have a clue.
Oct 12, 2005
1,013
Thanks for all your help. JBS are fitting the gauge, i am a retard when it comes to doing things like that, they said they needed a metal thread one. Thanks
Oct 12, 2005
1,013
I dont suppose anyone knows the internal diameter of the hoses with autometer gauges. I may just buy all the threads lol
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Do i win a prize for digging up the oldest thread ever?!
Just to ask, is this tapped into the pipe on the left of the engine AFTER the EGR and down to the front of the bumper?
I'm guessing its a case of drilling a hole a few mm's smaller than the threaded nipple and then screwing that in for it to 'self tap' itself?
Thanks all,
Jimski
seantdi
no smoke no poke!!
Jan 18, 2009
1,218
ireland
yup thats the pipe. bit size depends on the thread size of the nipple. mine was a M5 thread so i drilled a 4.2mm hole and threaded it with a tap and die set. if you dont have one i guess you could try thread it with the nipple or a bolt with the same thread size.. also you want to be very carefull when drilling not to let swarf down into the pipe
