I got mine from Apex mate and yes, it comes with T piece and 6 foot of nylon tubing. The T piece is the right size to tap into the fuel pressure regulator as I done with mine. Looked a little small for the DV install. Gauge works fine (only fitted mine today )
if you dont get one of the threaded adaptors , try demontweeks or one of the gauge manufactureres ,the threaded nipple for my gauge came in the gauge kit (defi)
all u need is the internal diameter of the hose your using , just watch when threading that , V easy to shear plastic threads on the boost pipe u cut ,
Thanks for all your help. JBS are fitting the gauge, i am a retard when it comes to doing things like that, they said they needed a metal thread one. Thanks
yup thats the pipe. bit size depends on the thread size of the nipple. mine was a M5 thread so i drilled a 4.2mm hole and threaded it with a tap and die set. if you dont have one i guess you could try thread it with the nipple or a bolt with the same thread size.. also you want to be very carefull when drilling not to let swarf down into the pipe
