Auto Lock on Ibiza
terry.h
Hi,
I have just been to my dealer to activate the auto lock facility and to get the doors to unlock when the key is removed from the ignition.
The guy told me that the latter had been enabled, which it has. It only unlocks the drivers door however and I would like to know if this is normal or should the passenger door unlock too?
Thank you
Terry
SEATcarsdirect.co.uk
Terry
the car knows what doors you unlocked when you get in the car
for example if you only unlock the drivers door with the fob only the drivers door will open
i hope this makes sense
Irfan
terry.h
Hi,
Even when unlocking all doors with the keyfob, only the drivers door unlocks when the key is removed from the ignition.
Is this a fault?
Terry
muddyboots
Still hanging around
Oct 16, 2002
5,739
Hi,
Is this a fault?
Terry
I'm fairly certain this is standard behaviour.
Resulting in passengers trying to tear the door handle off, not realising they have to pull it twice !!
My Mum is the worst, surprised she never broke it off. Now I try and hit the central unlocking button before her hand reaches the door handle.
Ol' Timer
873
Norfolk
I think the idea is that the car returns to the state when you originally unlocked the doors. In other words, if you pressed the button twice to unlock all the doors, it will revert to that when you remove the key. If you pressed the button once, it will only unlock the driver's door. I think that's the idea but I'm not sure it works in practice. I always use the unlock button on the driver's door when I stop.
nealo
88
Guisborough
my last mk 4 and my current one both only unlocked the driver's door even after pressing the remote twice before driving.
but once in a blue moon they would both unclock both doors. never worked out what i'd done differently. just weird.
Sorry i didnt get to check it this morning
will have a look for you on my way home
Irfan
terry.h
Thanks for all of the replies, seems like this is normal then. At least I know its not a problem with my car.
Terry
